need help
Old Aug 15, 2013 | 12:57 PM
projectRS92's Avatar
Car: 92 camaro RS
Engine: 305 TBI
need help
i need to put new intake manifold in 92rs tbi but all the one i see dont mach up.. they dont look like the stock one dont know if my stock tbi set up will bolt up to this one let me know if so ..our there is a better one what will work just not sure if my tbi will fit on that
Old Aug 15, 2013 | 01:45 PM
Ronny's Avatar
Re: need help
You need an adapter for a carb intake. Holley and Edelbrock sell direct replacements(TBI).
Old Aug 15, 2013 | 01:52 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
or this will be a batter idea and fit and thanks for letting me know
Old Aug 15, 2013 | 02:00 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
looked Holley Performance TBI Adapter not sure witch one is right one to get there are different can u show me witch on would work or should i go with the tbi intake manifold i posted
Old Aug 15, 2013 | 02:04 PM
Ronny's Avatar
Re: need help
The pic you showed is only a bit better than stock. Holley is good to 6500 rpms so they say. My Holley has seen 6000 rpms but it or my 7.4L TB(with inj pods) is a slight restriction.
Old Aug 15, 2013 | 02:07 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
http://static.summitracing.com/globa...3704_JY_ml.jpg this one right and can u show me what adapter i should use if i go with the non tbi manifold
Old Aug 15, 2013 | 02:25 PM
Ronny's Avatar
Re: need help
Summit maybe sells the adapter. I bought mine from Howell Engineering but never used it and returned it. It was .50 inch thick and 2.00 in bore.
Old Aug 15, 2013 | 02:33 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
so this one will work right with out the adapter
Old Aug 15, 2013 | 02:34 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
so this one will work with out the adapter ?
Old Aug 15, 2013 | 02:39 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
this is what i would need and would it fit under a stock hood
Old Aug 15, 2013 | 02:52 PM
Ronny's Avatar
Re: need help
I believe so. small block chevy has two choices one being vortec.
Old Aug 15, 2013 | 02:54 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
[QUOTE=projectRS92;5619510] this is what i would need and would it fit under a stock hood
Old Aug 15, 2013 | 02:55 PM
Ronny's Avatar
Re: need help
Not sure on stock hood. you would need to measure with play dough or modeling clay. I went to Howell since it was a 2.00 bore and .50 inch high. I also owned a single plane that was machined down to minimum for more clearance(vett hood). Never used. Now I wish I had given it a try and had it machined for port fuel.
Old Aug 15, 2013 | 03:02 PM
Car: 92 camaro RS
Engine: 305 TBI
Re: need help
thanks a lot for the help know i have to make up my mind on with one to do
