yanked the carb 350 for a 350 tbi
Old Aug 27, 2013 | 07:13 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
thanks for any help or suggestions.
removed a carbed 350. wanting to install a 350 tbi. I have a few questions.
1) will the original distributor work in newer engine?
2) what about the flex plate?
3) will there be any issues bolting this engine to a 350 turbo?
4) this is a vortec engine, not sure about the year!
I appreciate any help you guys can provide for me.
Old Aug 27, 2013 | 10:24 AM
Schurkey's Avatar
Re: yanked the carb 350 for a 350 tbi
No. Won't connect to the computer wiring harness. You may have problems with the distributor gear being incompatible with the camshaft, especially if this is a roller-cam engine. GM roller cams need the melonized distributor gear.
Flex plate from a two-piece rear-main-seal engine won't fit a one-piece rear main crankshaft.
Not if you have the right flexplate.
Far as I know, there were no Vortec TBI engines. At least, none with the '96-newer Vortec heads
Old Aug 27, 2013 | 11:31 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
thanks Shurkey. your info was a lot of help.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
pimp2303
Jul 27, 2017 02:03 PM
theshackle
Mar 5, 2017 06:37 PM
