91 Rs 305 TBI oil pressure problems
Old Oct 31, 2013 | 06:52 PM
flost0590's Avatar
Car: 1991 Camaro RS/2013 Outlander Sport
Engine: 305 V8
Transmission: 700R4 Auto
Hey guys,
I just picked up my 91 RS, it has the 305 tbi motor. I drove it about 100 miles home with no problems. The past few days i have taken it out, at first it will be fine, no problems. After the car warms up i see the oil pressure drops to 30 then to 0 when i am at a light. the only way to keep it up and keep the engine from stalling is to keep my foot on the gas pedal. Oil pressure will be around 60 then, as soon as I take my foot of the gas the car shuts off. can anybody tell me what they think this could be? Just so I know where to look first. I check my oil and levels are good, it didnt need any oil. I am also looking for a 91-92 front spoiler/valence if anyone is trying to sell one.
Attached Thumbnails 91 Rs 305 TBI oil pressure problems-603964_10201396948938174_1695914106_n.jpg
Old Oct 31, 2013 | 07:46 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 91 Rs 305 TBI oil pressure problems
could just be the idle control solinold.it may be idling too low.more rpms=more oil pressure.you might run through a can of fuel injection cleaner.seafoam has a good reputation.
Old Oct 31, 2013 | 11:48 PM
Schurkey's Avatar
First Guess: Oil pressure gauge problem due to defective sending unit. The pickup-truck sending units are infamous for failure. The seal leaks, the sending unit canister fills with oil. Damned things slosh when unthreaded from the rest of the engine. I bet the car sending units are either the same or similar.
Old Nov 1, 2013 | 04:37 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Any idea when this car had its last tune up with new plug wires and a fuel filter change?
Old Nov 1, 2013 | 09:26 AM
flost0590's Avatar
Engine: 305 V8
The guy i bought it from said he just did it. new fuel pump and filter, new injectors, new plugs, new wires. Thanks guys...I havnt had much time to get into to it since I bought it last weekend due to work. I will check what you have mentioned this weekend. I hope its nothing to serious and easy to fix.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
92purpz28
Aug 11, 2015 02:30 PM
