RPM drop/fluctuation
Old Jan 3, 2014 | 01:15 PM
AlwCamaro's Avatar
Car: 1990 RS Camaro
Engine: V8 5-liter
Transmission: 700r
First Post.
I drive a stock '90 RS V8 5L. When I'm "idling" in gear. (foot on the brake at a stoplight or foot off the brake but no gas engaged) I notice the engine drops 5ishRPM and then back to idle rhythmically. In some cases this causes my engine to shut off while in motion so it is dangerous.
Sorry if this is poorly-worded. What could this be? I have very little car experience.
Old Jan 4, 2014 | 08:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I moved this to the TBI forum. Figured you're more likely to get useable responses here.
Old Jan 4, 2014 | 09:46 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Re: RPM drop/fluctuation
sounds like bad spark plugs/timing...
Old Jan 5, 2014 | 03:25 AM
AlwCamaro's Avatar
Car: 1990 RS Camaro
Engine: V8 5-liter
Transmission: 700r
Thank you 57kid. And zero,
what should I do about it?
Old Jan 5, 2014 | 10:48 AM
zero13's Avatar
Car: 91 Z28
well,obviously change your plugs..no need to get fancy schmancy ones,just trusted durable..ac delco,etc.....make sure your timing is proper too..use youtube for searching how to articles...use these threads,but if youre a hands on guy(or not)..use youtube because people show you video versions of how to do things...you'll learn alot,and take more pride in your ride!!!!
Old Jan 5, 2014 | 11:32 PM
AlwCamaro's Avatar
Car: 1990 RS Camaro
Engine: V8 5-liter
Transmission: 700r
Cool, thank you for the help!
Old Jan 22, 2014 | 01:34 PM
mu33rto's Avatar
Car: 1992 RS
Engine: 305 5.0L V8 TBI
Check for a vacuum leak.
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
