Cam advice?
Old Jan 18, 2014 | 03:53 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Cam advice?
anyone care to make a cam recommendation for me? I'm getting ready to rebuild my carb'd 350, which I plan to convert to TBI in the near future, it's a flat tappet engine, with Vortec heads, edlebrock aluminum intake, nothing special really, preferred powerband would be in the 1500-4500 rpm range.
the vehicle weighs about 4000 lbs, automatic, with a 2000 stall converter, and 3.73's
Thanks-
Eric
Old Jan 19, 2014 | 11:35 AM
mccl6927's Avatar
Car: 92Camaro 89 Blazer
Engine: 3.1L Turbo
Re: Cam advice?
I went the cheap route and have the Summit 1102 cam (adv dur 278/288, Lift .421/.444) in my 350 blazer with heavily ported swirl port heads and a manual behind it. low end torque isnt the best but it pulls hard from 2000 to 5700 (and probably past that) where i have the fuel cutoff set. Im happy with it but im sure there are much better cams.
If you plan on changing a cam in a tbi setup you really should be prepared to tune to get the most from it.
Old Jan 19, 2014 | 01:39 PM
ericjon262's Avatar
Re: Cam advice?
the engine in the vehicle isn't TBI, and it's running vortec heads too. I plan to TBI or maybe TPI it a later date. I am well aware a tune would be required.
Old Jan 19, 2014 | 02:36 PM
mccl6927's Avatar
Engine: 3.1L Turbo
Re: Cam advice?
my thoughts were that heavily ported swirlports like mine flow pretty close to stock vortecs although the combustion chambers are different. just throwing out ideas man.
Reborn756
Sep 4, 2015 03:42 AM
lt1z350
Aug 28, 2015 05:57 AM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
