Left injector dripping, right injector seems fine
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Just wondering if I should replace the injectors, take them off and clean them somehow, or just poor fuel injector cleaner in the gas tank.
Re: Left injector dripping, right injector seems fine
take them out and get them cleaned locally. witchhunter is also highly recommended if you are in the US as he actually tells you what each injector flows at and can match them.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Why would you spend $22 on injectors that only cost around $50 ea new ?
http://www.ebay.com/itm/Standard-TJ4T-Fuel-Injector-/221314190215?pt=Motors_Car_Truck_Parts_Accessories&hash=item33875a8b87&vxp=mtr
Try Chevron Techron or the GM equivalent (AC-Delco X66 or 10-3000) in the gas tank before mechanical repair.
Consider buying Top Tier gasoline from now on.
http://en.wikipedia.org/wiki/Top_Tier_Detergent_Gasoline
Replaced the injectors. Got two remaned injectors, new gasket, and new O-Rings for $90 on eBay.
Fronzizzle
Mar 18, 2019 08:29 PM
