Lt1 cam swap issue- Wrong Cam bolt pattern?
the original timing chain on my '92 roadmaster is stretched (L05 tbi) i decided to do a cheap upgrade and go with a double roller set and also decided to get a cheap stock lt1 cam to swap while im in there. problem is, the double roller timing chain set i ordered through summit doesnt line up with the bolt holes on my lt1 cam shaft. this is the timing set i bought Mel 3-163S i thought any gen 1 timing set would work... any ideas? I've read the stickys here and couldnt find anyone else with this problem. cam is from a '96 bbody.
heres the set that is supposedly a direct replacement for my car KT3-499SA3
Here's what we're dealing with
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Lt1 cam swap issue- Wrong Cam bolt pattern?
thanks man, problem solved. the chain set i ordered was for a factory flat tappet motor
Yup, all the step-nose cams (retained with a plate bolted to the front of the block) had to have a revised (smaller) bolt circle because of the step-machining of the front of the camshaft.
This applies to the big-blocks, too. Learned that the hard way; not only did I need a different timing set, I also needed to order a different tang to drive the water pump on my marine water pump.
Car: check
Engine: check
Transmission: check
Don't forget to shorten the alignment pin on the cam. Otherwise it will strike the front timing cover, cause untold false knock and then cut a circle out of the cover..
RBob.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
I had a set of properly torque cam bolts back out once and do the same thing. I have used medium strength locktite on cam bolts ever since.
1992 Trans Am
Aug 8, 2015 08:16 PM
