Code 43 after filling up with 93 octane
Old Mar 3, 2014 | 07:03 PM
Bluezero05's Avatar
Hey all I have a new 1991 firebird. The VIN says it's a 305 but the previous owner said it was swapped out to a 350 but she didn't seem like she knew what she was talking about so I'm not sure. When I got the car I reset all the saved codes and dealt with the ones that popped back up immediately. I did see the code 43 in the history but I drove about 300 miles without it coming back. Last week I stopped at a gas station and the only fuel they had was 93 so I filled up with it. Now however, the code 43 is coming back once the car is warm and I accelerate hard causing it too run badly. I read somewhere that this could be because of the fuel not allowing it to pass the knock test? Thanks for the help.
Old Mar 3, 2014 | 11:06 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Re: Code 43 after filling up with 93 octane
Hmm I've never heard of that?? Have you checked to see where your timing is at? And is there a performance chip installed?
Old Mar 4, 2014 | 07:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the forced knock test is failing due to no knock.
RBob.
Old Mar 4, 2014 | 08:43 AM
Bluezero05's Avatar
Awesome thanks RBob. I guess I'll just run this tank down as fast as possible and go back to 87.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
indygene
Sep 26, 2015 11:21 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
