B Body Distributor hole
Old Apr 2, 2014 | 09:45 AM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
I have a 92 Roadmaster I was going to do a LT1 cam, and hopefully some L98 heads if I can find them.
I also have a ZZ4 intake I got for cheap, but of course it has the wrong size distributor hole. I have found where the B Bodies use a 1.75" hole and the standard size it 1.375". Is it possible to just bore out the hole on the ZZ4 intake to accommodate the B body distributor?
I run a machine shop so the machining is nothing, but I don't know if there are any other differences I need to be aware of.
Old Apr 2, 2014 | 12:23 PM
Schurkey's Avatar
Re: B Body Distributor hole
Do the EGR ports in the side of the manifold line up with exhaust gas passages in the heads?
Old Apr 2, 2014 | 02:19 PM
Mdenz3's Avatar
Car: 91 RS
EGR will be eliminated.
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
86IROC112
Aug 17, 2015 07:57 PM
