Quick Question on fuel lines
Old Apr 27, 2014 | 07:52 PM
ChevyNonsense's Avatar
Car: 1989 Camaro RS T-Top
Engine: 350 four main bolt
Axle/Gears: Factory
I have a 1989 Camaro RS it originally came with the 305 TBI but I swapped it for a 350. I want to convert to the carb setup.
My question is
The Fuel line rubber hoses at the driver side wheel tub has two female connectors of 3/8in. or?
I just need an insurance of fittings to buy for the pressure regulator.
Old Apr 28, 2014 | 01:43 PM
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
Re: Quick Question on fuel lines
If I am not mistaken I think a lot of guys ditch the female rubber hoses - then go from the cars frame hardline male end to these female AN6 adapters ...they are different sizes at 14 mm X 1.5 return and 16 mm X 1.5 supply not 3/8.... read about the fuel lines here at this URL http://z28boy.cz28.com/mods-fuellines.htm ..there are a lot of ways to do it -barbs etc I just like AN fittings ...I have included the p/n's and prices below for you ...I just went through this on my TBI to carb swap but haven't pressurized the system yet to check for leaks...hopefully it all works..... NOTE my 4309 regulator then has 3/8 N.P.T. inlet / outlets on it .
EAR-9894DBHERL AN to Metric adapter 14mm X 1.5 $8.97
http://www.summitracing.com/parts/ear-9894dbherl
EAR-9894DBJERL AN to Metric 16mm X 1.5 $8.97
http://www.summitracing.com/parts/ea...jerl/overview/
https://www.thirdgen.org/forums/carb...s-305-tbi.html
Old Apr 29, 2014 | 12:33 PM
Axle/Gears: Factory
Dude thanks alot this is very helpful
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
happyhapka
Aug 15, 2015 04:42 PM
