Fuel Pump primes with high beams?
Old May 18, 2014 | 06:52 PM
tpastorok's Avatar
When I have the key turned to the position before starting, where the fuel pump primes, if I turn my high beams on the fuel pump primes again...and then when i turn them off it primes...again. Is this normal? Lol. I have a theory but its a very far out shot in the dark, and mostly just because I was reading about carb conversions recently. Could it be that someone had it swapped to a carb at some point and that was their way of manually priming the fuel pump?
Old May 19, 2014 | 12:18 AM
steveo_'s Avatar
Re: Fuel Pump primes with high beams?
remember pump prime is under ecm control, so something is draining enough power or causing a momentary spike, which causes ecm reset.
what, i have no idea.
look for chopped wiring that someone might have botched
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
92camaroJoe
Aug 13, 2015 06:07 AM
