Acceleration problem
Old Jun 6, 2014 | 08:28 PM
Bluezero05's Avatar
Hey all, I bought a 91 Firebird with the tbi 305 a few months ago. Since then I have been trying to pin down a problem with the acceleration. When I press the gas pedal from a stop the car feels like it has weak acceleration and feels like it is bogging but if I press it about a centimeter more it jerks and suddenly takes off. It also does the same thing after it shifts into second. It's pretty bad after the car has been sitting for a few hours and is cold but also happens to a lesser extent when it's warm. So far I have replaced cap, rotor, plugs, wires, tps, and fuel filter and the car isn't throwing any codes. Also I have only been able to get a max of 14 mpg out of it even on a 140 mile highway trip. Any help is appreciated thanks!
Old Jun 6, 2014 | 10:53 PM
Schurkey's Avatar
Re: Acceleration problem
Put a scan tool on that vehicle and look at the data stream. A fuel pressure tester would also be a good idea.
What is the fuel pressure when the bog occurs?
What is the short- and long-term fuel trim?
How many O2 cross-counts?
What is the O2 voltage when the bog occurs?
Is the knock sensor retarding timing when the bog occurs?
What temperature does the computer think the engine is? Is it realistic?
Old Jun 6, 2014 | 11:10 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Is the TV cable hooked up and adjusted correctly?
Old Jun 7, 2014 | 08:37 AM
Bluezero05's Avatar
After I get out of work I'm going to look into the fuel pressure tester. Can you recommend an affordable scan tool?
Also, about the tv cable, when I bought the car it wasn't adjusted correctly as far as I could tell so I adjusted it click by click over a period of a couple weeks until it shifted tight but not hard and so far it seems ok.
Old Jun 7, 2014 | 09:09 AM
Schurkey's Avatar
A used professional-grade scan tool will be five times as helpful as a brand-new consumer-grade junk scan tool.
I have had excellent success with the old Snap-On "Red brick" MT2500/MTG2500. Either one is a "winner" for occasional use, and there's always a selection of 'em on eBay and sometimes on craigslist depending on where you live.
As long as you buy one with software new enough for your vehicle, and the appropriate tool-to-vehicle adapters, you should be set.
Old Jun 8, 2014 | 12:17 PM
Bluezero05's Avatar
I think I may have solved the problem. A few months ago I bought a Pro Flow air filter but it didn't mount up correctly and was loose. Yesterday I put the stock air cleaner back on with the appropriate wing nut and the problem seems to be gone. Is it possible that air was being sucked in from under the ring that sits on the throttle body since it was so loose?
Old Jun 8, 2014 | 12:49 PM
Schurkey's Avatar
Anything is a possibility. I have no trouble believing that a low-quality, poor-fitting air cleaner could cause a driveability problem. I'm not sure HOW it would cause that problem...but if it's fixed, it doesn't really matter any more.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
