map sensor readings
Old Jun 8, 2014 | 05:09 PM
acerulz's Avatar
Car: 1984 Cadillac Brougham
Engine: 1989 Iroc Z 350
map sensor readings
on my 89 350 tbi, its over fuelling itself. absolutely all sensors are up to specifications, and the motor is new with vortec heads on it. all scanner data is good except for my map sensor readings. The engine vacuum is up to 17-18 in. but the scanner map data is showing 9 in. at idle. even tried vac test at map sensor and its showing good vac, but not according to the scanner. tried a couple I had laying around here and still get the same readings. any ideas??
Old Jun 8, 2014 | 08:54 PM
Schurkey's Avatar
Re: map sensor readings
Defective wiring/corroded connections between sensor and ECM???
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
squiggy2
Aug 9, 2015 09:30 PM
