Knock sensor
Old Jun 9, 2014 | 06:16 AM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
Knock sensor
Would a knock sensor not working properly affect running only when its 40 deg. or colder? And how can I test it to make sure if it is working?
Old Jun 9, 2014 | 10:30 AM
Schurkey's Avatar
Re: Knock sensor
I'd think that would be unlikely.
Best way: Connect a scan tool, look at knock sensor/engine timing data. Put automatic transmission in "low", foot HARD on brake, stab gas pedal momentarily with other foot. You should see the knock sensor become active, and the timing retard. If you have a manual trans, you'll have a helper watch the scan tool while you drive the vehicle. When you get to high gear, stab the gas pedal when it's safe to do so. Sudden, heavy throttle should make the sensor active.
Sorta-kinda, maybe acceptable way: Engine at normal operating temperature, idle speed. Connect timing light. Tap engine block, head, or intake manifold with a small hammer--not hard enough to cause damage. Timing should retard momentarily, then advance to "normal" with each tap.
Either way, you need to be careful. My V-6 engines have so much piston slap that the knock sensor is perpetually trying to retard timing.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
