CFI EGR Question
Old Jul 1, 2014 | 11:07 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
CFI EGR Question
So, my buddy has an '84 Corvette with Crossfire Injection.
It runs fine, except for surging at idle. My car used to do that. Replacing the throttle shaft bushings in the TB solved it. I told him that.
He showed it to an old guy who loves CFI Corvettes, and knows a whole lot about them. He pulled the hose of the EGR, stuck his thumb over it, and the surging stopped. He told my budding using a block-off plate, or even simpler, putting a ball bearing in the hose would solve the problem. My buddy put a ball bearing in the hose, and it's running great.
In our cars, you can't just block the EGR, you also have to turn it off in the ECM, don't you? I thought CFI was the same?
Old Jul 1, 2014 | 11:27 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
You have to tune it out or you get a CEL.
Old Jul 2, 2014 | 12:14 AM
Engine: L03 305 TBI
Re: CFI EGR Question
Were you talking about on my TBI, or his CFI? His car is running great.
Also, what is a CEL?
Old Jul 2, 2014 | 12:27 AM
Axle/Gears: Stock
On your TBI not sure about CFI.
Cel is check engine light. EGR being unplugged or blocked off won't affect performance.
Old Jul 2, 2014 | 01:41 PM
Schurkey's Avatar
Or fix the EGR valve so it stops passing exhaust gas at idle.
Likely has carbon deposits on the pintle so it won't seal to the seat.
Old Jul 2, 2014 | 03:51 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
In this case it sounds like a solenoid issue, not an EGR valve.
Old Jul 2, 2014 | 07:25 PM
Engine: L03 305 TBI
OK< so what I'm curious about is, if you do away with EGR on a 3rd gen, you have to tuen EGR off in the ECM, don't you?
What happens if you don't turn it off in the ECM?
Old Jul 2, 2014 | 07:27 PM
Axle/Gears: Stock
You get a CEL. Nothing more.
Old Jul 3, 2014 | 01:37 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Actual it runs lean and pings!
Old Jul 3, 2014 | 01:38 AM
Axle/Gears: Stock
Well there you go then haha.
Old Jul 3, 2014 | 02:25 AM
Schurkey's Avatar
Yes, you're correct. My mistake.
Old Jul 3, 2014 | 04:52 AM
Engine: L03 305 TBI
So, the CFI Vette with the disabled EGR is not throwing a code.
He said it was running fine; I'll ask about the pinging.
If he does away with EGR, doe he need to disable it in the ECM, as well?
Old Jul 3, 2014 | 03:43 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Yes. EGR is activated by the ECM during cruising and some light load driving conditions, then the ECM commands a leaner mixture with additional SA to take advantage of the cooler combustion, provided by the EGR (effect of the Recycled Exhaust Gasses), to improve MPG.
If no Exhaust Gas is Recycled, the combustion will maintain its temperature and the commanded highway mode will cause early lean combustion with the result of engine knock.
Old Jul 5, 2014 | 05:27 PM
82tarecaro's Avatar
The egr is activated by a solenoid so by blocking off the port I do not think you will get a cel as the computer is just activating the solenoid, not getting an improper reading from a sensor.
Old Jul 7, 2014 | 04:46 AM
thomas1976's Avatar
Car: 91 Trans am
I do not think he will get an error code from unhooking the EGR solenoid. But the ECM will still lean the fuel mixture and add additional SA during highway mode, to take advantage of the additional exhaust gas the EGR is supposed recycle during that condition.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
