TPS connector bad?
Old Jul 2, 2014 | 12:53 AM
iaxbird's Avatar
Car: 91 Firebird
Engine: 305 cid LU5 Crossfire Injection :/
TPS connector bad?
So i have been having issues with this one since i bought it. It keeps throwing a code for the TPS and i put a new one in and upon testing the voltage to set the TPS i found something weird. I noticed That when i had my multi meter on the middle wire of the TPS wires coming from the harness with the red on the wire and black on a sanded piece of the body, that the car idles fine when i ground that wire... and when i take the cathode off of the body where i grounded it, it goes back to idling spastic and dying/or back firing... should i splice in a new throttle position connector? or is there something more I'm missing?? i sanded and cleaned every ground i found on the car after that to see but it didn't make a difference... plugs wires distributor cap and rotor are new as well as the battery cables... Ive been stumped on it all weekend i want to take the car to a car show for the 4th of july this weekend because the body and everything is clean but it just never ran right from when i bought it... Its got an LU5 motor, So i already checked and fixed vacuum leaks, I did not replace the fuel pump yet, but injectors are clean when i "ground" that TPS wire i can see them spraying fine, No exhaust leaks, Ive really went through some of the major problems with this bastard thing running... Help!lol
Old Jul 2, 2014 | 01:39 PM
Schurkey's Avatar
Re: TPS connector bad?
Where does that middle wire go to? Trace it and find where it's open or corroded.
Old Jul 2, 2014 | 03:51 PM
iaxbird's Avatar
Car: 91 Firebird
Its the wire highlighted in the picture... it goes into the harness ill have to do some digging. its really been giving me hell!
Attached Thumbnails TPS connector bad?-82crossfirethrottlebodyfuelinjection-copy.jpg
89GTAOz
May 16, 2020 09:31 AM
TheJoeY88
Dec 31, 2016 07:30 PM
soarestransam
Aug 24, 2015 08:15 AM
perZ
Aug 15, 2015 01:17 PM
