No Idle TBI
Old Jun 30, 2014 | 11:32 AM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
No Idle TBI
I need some help. I parked my completely stock ‘89 IROC w/305 TBI with 65k miles on it about a year ago as I was working out of town. When I parked it, it ran perfect.
I went to get it out of storage after about a year and found that while it started right up and ran, it would not idle. I got it out on the highway and it ran well with no hesitation while accelerating or driving at highway speeds, but would die as soon as I let it drop below 1500 rpm. I went through all of the postings I could find pertaining to a TBI idle condition and found that my problem appeared to be most likely related to a faulty IAC. I replaced the IAC but I still have a “NO idle” condition. Engine temperature has no effect on the lack of idle. There are no cracked or missing vacuum lines and no check engine lights or codes given. The car runs great as long as the car is above 1500 rpm.
Any suggestions would be appreciated
Old Jun 30, 2014 | 12:19 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Re: No Idle TBI
Is it throwing any codes?
Old Jul 1, 2014 | 12:35 AM
Richboll's Avatar
Engine: 305 TBI
Re: No Idle TBI
Nope. No codes and no Check engine light.
Old Jul 1, 2014 | 12:40 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Have you check fuel pressure?
Old Jul 1, 2014 | 02:06 AM
Schurkey's Avatar
Re: No Idle TBI
How old is the gasoline?
Old Jul 1, 2014 | 09:16 AM
Richboll's Avatar
Engine: 305 TBI
Re: No Idle TBI
No, I haven't checked fuel pressure. I can hear the pump run and I'd think I'd have a problem with acceleration if the pump was bad. It will fire right up and when I get it on the highway it will pull strong as long as l stay on the gas. When I've had fuel delivery problems in the past the car would stumble and refuse to accelerate. I'll see what I can do to check it. Any suggestions on what should it be?
Old Jul 1, 2014 | 09:17 AM
Richboll's Avatar
Engine: 305 TBI
Re: No Idle TBI
About 3 months old. When the problem appeared, I took and filled the tank. No difference.
Old Jul 1, 2014 | 12:20 PM
Axle/Gears: Stock
Should be 10-13. Mine had similar symptoms way back in the day. Turned out to be the host between the pump and sending unit.
Ran fine except wouldn't idle. Didn't know it, but it was leaning out everywhere
Old Jul 2, 2014 | 11:12 PM
Richboll's Avatar
Engine: 305 TBI
Re: No Idle TBI
Ok, I'll try to check it out this weekend. When you had the problem were you showing any codes?
Old Jul 3, 2014 | 12:41 AM
Axle/Gears: Stock
Nope. Non at all
Old Jul 3, 2014 | 01:07 AM
Richboll's Avatar
Engine: 305 TBI
Re: No Idle TBI
Nope. Non at all
Ok, I'll let you know what I find. Thanks for the help.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Sep 4, 2015 07:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
