hard start
Old Jul 28, 2014 | 01:42 PM
night_rider1126's Avatar
Car: 90 camaro rs
Engine: 5.0 tbi 305
Transmission: 700 r4
hard start
so I have a 1990 camaro rs 305 tbi and I've come to realize if I let the car sit for more than a 8 to 10 hours it's hard to start back up takes 15 to 20 seconds to finally turn over and start any idea what this could be
Old Jul 28, 2014 | 05:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: hard start
Check the fuel pressure, at key-on, engine-off the ECM will run the pump for 2-seconds. Then again after it receives reference pulses from the distributor. Bad relay or ECM and the oil pressure needs to build first to activate the fuel pump.
Leads to long cranking time.
RBob.
Old Jul 28, 2014 | 09:36 PM
Car: 90 camaro rs
Engine: 5.0 tbi 305
Re: hard start
How do I check fuel pressure I do no have a Schrader valve I've looked for one
Old Jul 28, 2014 | 10:51 PM
Schurkey's Avatar
Re: hard start
"Turn over" is a synonym for "cranking".
Does it really take 15 to 20 seconds for the starter motor to engage? Or does it crank for 15 to 20 seconds before the engine runs?
Old Jul 29, 2014 | 01:03 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: hard start
http://smile.amazon.com/Tool-Aid-376...essure+adapter
Old Jul 29, 2014 | 06:14 PM
ex-x-fire's Avatar
Re: hard start
Before you try to start it, pop the air cleaner & have someone watch as the injectors spray. They should spray right away as you crank it.
Old May 29, 2015 | 08:46 PM
Car: 90 camaro rs
Engine: 5.0 tbi 305
Re: hard start
figured it out it was the hose from my sending unit to the fuel pump the rubber hose yea it basically fell apart in mhy hand it was sucking air and fuel weird but change out hose and ran great
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
