fuel pressure
Old Aug 10, 2014 | 06:25 PM
night_rider1126's Avatar
Car: 90 camaro rs
Engine: 5.0 tbi 305
Transmission: 700 r4
fuel pressure
Hey guys just needed to know how to check fuel pressure on my 1990 305 rs I didn't find a port to check it and what's proper pressure in the system
Old Aug 11, 2014 | 09:22 AM
Schurkey's Avatar
Re: fuel pressure
Please search before posting. This has been covered many, many times.
GM TBI systems don't have a pressure tap. You need to buy an in-line tap, and the gauge to connect it to.
There are two primary styles of in-line pressure tap. One kind fits in the port of the TBI where the fuel inlet would go, the other replaces the fuel filter.
Typical TBI pressure is 9--13 psi; although some systems go higher. The service manual for your vehicle will tell that tale.
Old Aug 15, 2014 | 04:46 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: fuel pressure
I use the "Actron 7817", with the T on the feed line next to the alternator. I also fix the gauge under the wiper arm, to verify if the pressure drops under load. Pressure must stay constant.
Here is a pic of the inline T adapter https://www.thirdgen.org/forums/atta...-t-adapter.jpg
I would suggest using an AFPR and set pressure to 13 PSI.
Old Aug 15, 2014 | 01:27 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: fuel pressure
Not sayin this is the proper way but i found a fuel pressure gauge that came with a T meant for rubber lines so i just cut the rubber feed line and put it there. Works for me
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
