305 TBI, won't idle and surges when runs
Old Sep 26, 2014 | 04:06 PM
5.0L5SPD's Avatar
My 88, 305 TBI/5 spd had been sitting for a while, but started regularly. Not long ago, when I started it, it would idle really high 3500 or so, and then drop to almost nothing and keep doing that. Once I got it warm, it would idle right. I'd hold it at 2,000 to warm it. When I drove it, it would drive ok if real ginger on the accelerator. Any real acceleration and it would stumble and buck. The problem continued to worsen and eventually wouldn't idle but did kick a code. MAT sensor and TPS. I've replaced both. It's still doing the idle issue but won't start idling even once warm now and won't stay running even when trying to hold at 2,000. No codes are showing up. HELP!? I read thru a few posts, but haven't seen the same scenario, so any thoughts are appreciated.
Old Sep 26, 2014 | 08:08 PM
ex-x-fire's Avatar
Re: 305 TBI, won't idle and surges when runs
Check the fuel pressure, you'll need an adaptor to test it. Autozone rents out tbi testers that includes the adaptor. Spec is 9-13 psi. These cars will run on very low pressure.
Old Sep 29, 2014 | 02:38 AM
mauijerky's Avatar
Car: 91 RS
Axle/Gears: Stock w/ 3.73 posi
I'll backup the fuel pressure check idea. Could be a slit or hole in the short rubber hose that connects the fuel pump to the hanger assembly. Also, if you've solved the stumble issue yet still have weird idle problems, could be time for a new TBI flange gasket.
Old Sep 29, 2014 | 07:09 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Muffler bearings...
Old Sep 29, 2014 | 10:29 AM
5.0L5SPD's Avatar
Thanks, I'll try it.
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
