high idle when clutch engaged?
Old Oct 1, 2014 | 09:31 PM
89formyoula's Avatar
Car: 89 formula
Engine: bolt on 305 tpi
Transmission: 700r
Axle/Gears: 342 posi
I have a 91 firebird...305 TBI 5 speed....every time I push the clutch in or just pop the car out of gear the idle will shoot up to 1500 rpms..but only while driving...when I stop the idle slowly goes down...I've only replaced the tps & it didn't change a thing...any help would be greatly appreciated
Old Oct 1, 2014 | 10:59 PM
Schurkey's Avatar
Re: high idle when clutch engaged?
High idle when clutch engaged...or disengaged? Sounds like you're complaining of high idle when clutch is DIS-engaged.
Connect a scan tool. See what the commanded idle speed is, and compare to actual idle speed.
theshackle
Sep 17, 2020 08:26 AM
777Shock777
Oct 29, 2015 04:30 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
