EBL Flash wont flash
Old Oct 12, 2014 | 02:35 PM
WagonmasterRuss's Avatar
Car: 1993 Caprice Classic "Woodie"
Engine: 350 TBI W/EBL Flash
Transmission: 4L60 S10 converter
Axle/Gears: 8.5, Torsen T2, 3.73s
My old laptop died so I switched to my windows 7 laptop. I bought a new serial adapter and I am getting data in WUD but it will not flash a new bin, it just keeps failing.
suggestions/
Old Oct 12, 2014 | 04:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Flash wont flash
Need a USB to Serial adapter cable that uses the FTDI chip set. They are the only ones we have found that can handle the high data rate and turn around times.
RBob.
Old Nov 23, 2014 | 11:06 AM
Thanks,
Can you give me the name of the one you bought?
Old Nov 24, 2014 | 10:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
We use this FTDI cable:
UC232R-10
USB Cables / IEEE 1394 Cables USB to RS232 Embeded Converter, 10cm
RBob.
Old Nov 24, 2014 | 10:17 PM
Thanks!
RS Reaper
Oct 17, 2018 07:52 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
lewandom
Oct 1, 2015 08:15 AM
85Special
Sep 3, 2015 04:21 PM
