Quick EBL Flash/sensor questions
Old Nov 18, 2014 | 02:00 PM
Flightoficarus's Avatar
Hey all,
In the midst of removing wiring/clutter in my engine bay, and have some more questions, as I'm getting ready to finally remove my 305.
There will be an L31 going into my car. I will be running TBI on it, and was planning to go the EBL Flash route for tuning. Just curious on if I will still need to swap out certain sensors, like the ESC module, and the knock sensor for the 350 versions? (I'm aware that it's a must, or at least strongly recommended for a basic 305 to 350 TBI swap) And if so, is swapping them just a "plug and play" procedure with the same wiring harness/ECM? Or is there more to it? Thanks in advance!
Old Nov 19, 2014 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Quick EBL Flash/sensor questions
You can swap the knock sensor for a 350 one. The filter can also be changed but since that is much easier can do it at any time down the road. Same harness and connectors for either.
A decent app for these would be a '89 Caprice with the 5.7l L05 engine.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
