2 wire O2 sensor
Car: 1970 K25, 1986 K5
Engine: Both 350s
Transmission: SM465
Axle/Gears: Dana 44/60 10-bolts
2 wire O2 sensor
I had found the thread awhile ago that talked about changing from a 1-wire O2 sensor to a 2-wire O2 sensor. Now I can not find it for the life of me. Anyways, which 2-wire O2 sensor is used? I know the "heater" wire needs to hook up to a 12V source when in run. Thanks,
Jim
Jim
Car: check
Engine: check
Transmission: check
Re: 2 wire O2 sensor
Need a 3-wire O2 sensor, such as the AC Delco AFS-74
The two wires of the same color are heater + and heater ground (no polarity). The third wire out is the signal, with the signal ground being through the sensor body.
RBob.
RBob.
This old thread of mine has P/Ns and pictures of how I did it:
https://www.thirdgen.org/forums/tech...heated-o2.html
dbrochard
Sep 19, 2015 08:13 PM
