code 44 lean exhaust indicated ?
Old Dec 8, 2014 | 03:50 AM
camarowner's Avatar
I have a 91 Camaro rs swaped 305 with 350 long block used Manifolds, TBI, Engine programmer all from original 305. Car ran great for 1st 25k miles. Now the SES light comes on code 44 and the cars missing big time. fuel pump presser good Changed fuel filter, wires, plugs, cap and rotor no change. Replaced injectors and presser regulator no change. engine programmer is next on the list .
Any suggestions
Old Dec 19, 2014 | 06:38 PM
Schurkey's Avatar
Re: code 44 lean exhaust indicated ?
Any suggestions
You're using a fuel curve intended for a 305 on a 350? Of course it's lean.
SCAN TOOL: What is the data stream showing for short- and long-term fuel trim; coolant temperature, engine vacuum, EGR, etc?
Mind you, I chased a false "lean" condition on my TBI truck that turned out to be a defective O2 sensor, but that was a 350 fuel curve on a 350 engine.
Old Dec 19, 2014 | 09:01 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Code 44 may indicate dying or cold O2 sensor - get a scan tool or WinALDL to see if your O2 voltage swings once engine enters close loop CL. A good O2 sensor should show rich condition during cold start around 700 to 850 mV and then start oscillating between 200 to 800mV in CL.
//RF
Old Dec 21, 2014 | 06:48 PM
camarowner's Avatar
It was the fuel pump. Checked pressure it was 10lbs which should have been enough However I pinched off the return hose that should of raised the pressure and it didn't so changed the pump now I got 15 lbs it run great again. thanks for your reply
Old Dec 22, 2014 | 10:33 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Even a STOCK TBI engine needs ~13 psi of fuel pressure to run well.
Old Dec 22, 2014 | 12:38 PM
Bigfoottpi11's Avatar
Any suggestions
Mine threw that code once when my o2 sensor was loose
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
