081 heads + cam TBI build need help
Old Feb 10, 2015 | 05:03 PM
maxpain's Avatar
Car: Firebird Formula '86
Engine: 6.0 LQ4
Transmission: 4l65E
Axle/Gears: Hawks 8.8 3.55
Hey guys!
I got myself a nice set of 14101081 heads.
I am going to port them, and put 1.6 exhaust valves on them.
Cam is going to be lunati 20080660 with 447/.471 lift.
I have no idea which springs to get for this and where to get the 1.6 exhaust valves. Would be even better if I could get a set of every moving part for the heads in one place.
I would appreciate links or contacts where to get this stuff.
I will dyno before and after this build.
Old Feb 10, 2015 | 06:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 081 heads + cam TBI build need help
You should contact lunati to see what they recommend but I'm sure lt4/zz4 springs or cc981-16 would work fine. The lt4 spring maynot require as much additional guide cutting. Cutter can be purchased at summit or jegs from comp. you may want to cut threads for studs or pin the stock pressed in ones.
Old Feb 19, 2015 | 11:13 AM
maxpain's Avatar
Engine: 6.0 LQ4
Transmission: 4l65E
Got the springs info from them.
But that is all they sell. And I need pretty much everything else there is in the heads! And first of all - oversized valves.
Any other links?
Old Feb 21, 2015 | 11:54 AM
Engine: Lb9
Transmission: M20
Links to what ? Guide cutters ? Spring retainers/shims ?
http://www.alexsparts.com/categories/VALVE-SPRING-KITS/
Amazon.com: Competition Cams 4732 11/32" Arbor/Pilot for Spring Seat and Valve Guide Cutters: Automotive Amazon.com: Competition Cams 4732 11/32" Arbor/Pilot for Spring Seat and Valve Guide Cutters: Automotive
Look at the bottom of the Amazon link for the additional cutter
http://m.summitracing.com/parts/mrg-806g
Old Mar 4, 2015 | 12:37 PM
maxpain's Avatar
Engine: 6.0 LQ4
Transmission: 4l65E
I found a company that will port the heads for me and cut them for a larger valve. So I don't need a cutter anymore. But I still need everything moving in the heads.
Will this kit fit? http://www.ebay.com/itm/New-HP-Head-...-/221593322925
Old Mar 4, 2015 | 01:57 PM
Engine: Lb9
Transmission: M20
They should be 11/32 valves, the max lift at installed height shows .500 . Looks like they will do the trick and are very affordable. The only thing left would be a valve job and shim the springs look at Alexparts .
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
89-S-dime
Aug 12, 2015 11:57 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
