CC Carb to TBI
Old Mar 1, 2015 | 08:17 PM
jahblah's Avatar
Car: 87' Firebird Formula
CC Carb to TBI
Researched and my car originally came with an LG4 and an computer controlled carburetor. Neither are in the car now due to previous owners swap, and the car doesn't run well sometimes. Has a regular old quadrajet on it.
How hard would it be to convert the car to TBI using the current harness? I'm sure I'd need a different computer and what not. The tank already has the CC-carb 3psi electric pump and I also have a brand new TPI pump from an old build as well I could install.
Old Mar 2, 2015 | 03:26 PM
jahblah's Avatar
Re: CC Carb to TBI
Anyone?? What about the moderator "five7kid"? I'd read a LOT of CC carb threads where he has chimed in.
Old Mar 2, 2015 | 03:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: CC Carb to TBI
It won't be easy using the stock CCC harness. They aren't enough wires and the ECM harness connectors are the wrong style.
Best bet would be to get a f-body TBI harness and use it in place of the CCC harness. An '88 harness will be easier to install then a '92 harness due to other connectors.
Other then that the swap is easy.
Note that tuning will be required as TBI engines have swirl port heads while an LG4 engine does not.
RBob.
Old Mar 2, 2015 | 04:36 PM
jahblah's Avatar
Re: CC Carb to TBI
RBob.
If i'm switching harness, may as well look for a full tpi setup. But thank you my good man. That is all I needed. Much appreciated.
Old Mar 3, 2015 | 12:19 PM
MONGO83's Avatar
Re: CC Carb to TBI
I have a TPI set up but no harness. PM me if your interested.
Old Mar 9, 2015 | 11:22 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: CC Carb to TBI
Existing CCC distributor will work with TBI ECM. You will need to change plug on TBI harness to mate into standard 4-pin weather pack flat plug used in CCC dizy. Swap is not that difficult - just need to take your time to route harness correctly..
//RF
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
