runs rough then dies
Old Apr 4, 2015 | 06:10 PM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Ok guy I'm at a stand still here on my lo3 it ran perfectly then one day on my way to school it started running bad back firing real bad would not run well I checked codes I had the code 42 so I assumed it was the est because my prob goes away when I undo the wire by the blower motor but with the wire plugged in in back fires out the tbi and exhaust times good have not messed with it but so far I put a new dizzy in that came with new icm but I'm still having the prob your thoughts guy and plz don't lecture me about not useing proper grammar
Old Apr 15, 2015 | 11:52 AM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: runs rough then dies
I had roughly the same problem one time. Car would backfire and hardly run when it warmed up. So I replaced every dam sensor on the car and it didn't fix it. So one day I just turned my key on all the way but didn't start it and I herd a rapid clicking noise, I poped the hood and my injectors were just randomly firing for no reason. Turned out my ECM was bad. Thats just my two cents.
Old Apr 15, 2015 | 12:39 PM
tchampton's Avatar
Car: 1989 Fourmla
Engine: 5.0 305
Thank you is kinda been thinking that but when I have the est wore it runs good but I can't drive it on the highway like that due to needing timing to change
eightsixseven
Dec 16, 2024 01:50 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
