won't crank after spark plugs and valve seals
Ok, once again any help would be great. Basically I noticed oil on spark plugs so I changed spark plugs and valve seals. now engine turns over but wont crank. I did not move distributor and Ive verified plug locations.
Re: won't crank after spark plugs and valve seals
Do you mean that it cranks but won't start? Do you have proper compression when performing a cranking compression test? Do you have spark and fuel spray?
First Guess: Incorrect lifter preload adjustment.
right, it won't start. I think you right about it being a preload adjustment issue. now I just need to determine which is intake and which is exhaust.
Car: 91 Camaro RS
Engine: 305 TBI
The intake side lines up with your intake ports and your exhaust side lines up with the ports on your exhaust manifolds/headers. That's the easy way to tell.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
