EBL questions
Old Aug 13, 2015 | 06:04 PM
onebadazzsrt's Avatar
Car: 93 Caprice Wagon
Engine: LO5 350
EBL questions
I just finished my build, the car will not run with the map sensor plugged in. If I un plug the map the car runs but idles around 1300 rpm. All the items listed in my sig are part of the build. What is a good starting point to get the car to idle with the LT4 hotcam?
Old Aug 15, 2015 | 01:30 AM
Engine: LO5 350
Re: EBL questions
I checked voltage from map and tps. I am only getting .65 volts
Old Aug 15, 2015 | 07:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL questions
Look for a pinched wire. The +5 volts goes to the MAP sensor and the throttle position sensor (TPS).
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
soarestransam
Aug 24, 2015 08:15 AM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
