Please Help Me With Timing
Old Dec 19, 2001 | 10:30 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am home from school and can work on my car now. I have a timing gun but I am not sure if I am doing it right. I painted the balancer line so I can see it but my timing tab doesn't have numbers on it. Also what exactly do you unplug to set the base timing. I unplugged the distributor (not the one that goes to the coil) but the car won't even start. So I unplugged the little gray plug that is close to the coil. The tach doesn't work when this is unplugged, but there isn't a check engine light, which I thought there should be. I think I am close. I have no knock and the idle is great but the car has TREMENDOUS hessitation. I have the light right smack dab in the middle of the timing tab. I am not sure if I disconnected the ECU correctly. Pleae help.
Old Dec 19, 2001 | 10:38 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The plug that you need to unplug when you set the timing is on the passenger side firewall. It's a little brown wire that comes out of a bundle, has a little connector, and then goes back into the bundle. I hope that this helps.
Old Dec 19, 2001 | 10:45 AM
firbird's Avatar
you sould have numbers on the timing tab, if it is stock. I couldnot see mine on my lo3 so i took a metal brush and scraped it off intill it turned all silver and i could see it. about hte pluge you take off to set timing it is the est wire it is a single pluge that is located over by the strut on the passenger side or up on the firewall, around in the ac stuff.
Old Dec 19, 2001 | 10:52 AM
Mark305TBI's Avatar
See!! There it is!!
Old Dec 19, 2001 | 08:28 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thank you so much guys. Imagine that...the dealers didn't re-time my car right. It was dark when I went out and checked the car but my EST connector looks closer to the strut assembly and not right against the firewall. I wish I could reach through this computer and shake your guys hands. Well let me fix it forst than I will let you guys know the true results of my intake swap
Old Dec 19, 2001 | 09:15 PM
firbird's Avatar
yea mine is not really in that loacation either it is more near the strut, lol your welcome anytime
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
