Crazy idea
Old Dec 19, 2001 | 05:50 PM
Buck268's Avatar
Crazy idea
Would I be possible (hypothetically) to use the A.I.R. pump as a sorta blower for the engine (super charger)? Not that I plan on even thinking about it, but figured if anyone wanted to expand on it.... I dunno, any thoughts?
Old Dec 19, 2001 | 06:09 PM
breathment's Avatar
i thought of somthing simular to that, but it doesn't blow enough air, nothing close to what ud need.
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I'm no expert, but when I took off the pipe to it and felt the air pressure it puts out (was almost considering leaving it in place to blow air onto the the engine for cooling! ), it seemed way to weak to make any sort of difference as a blower. I'm no expert, but I'd guess that the negative sucking vacuum from the intake is probably way stronger than any positive pressure that AIR pump is putting out...
What the hell, try it and let us know what happens. It can't hurt, can it?
Old Dec 19, 2001 | 06:21 PM
Buck268's Avatar
thanx fer the thoughts. Like I said, just an idea i figured I'd throw out fer ya'all.
Old Dec 19, 2001 | 11:54 PM
ZRATED's Avatar
Nope not enough volume, but it could throw a spit ball pretty hard!!!!
Old Dec 20, 2001 | 10:58 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Some guy did this to a go cart motor, and it worked, this also worked for a small block but they had to put like 6-7 on. Do a search on the power adder board.
83 Crossfire TA
Jan 3, 2016 01:26 PM
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
z28guy134
Sep 1, 2015 11:50 PM
