MSD Ignition Blaster Coil....
Old Dec 20, 2001 | 07:01 AM
RS91's Avatar
I just Installed My new MSD Ignition Blaster and I must say my RS91 runs alot smother now... and it only took me about 5 minutes to install...I will install the rest of MSD Cap, Rotor and Spark plug wires this weekend....
I'm just letting everyone know that it's worth the modification..
Old Dec 20, 2001 | 12:29 PM
CODY BEHNKE's Avatar
Since there is no where else to post I have one for sale. $30
Old Dec 21, 2001 | 03:22 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Agreed
Yeah, I agree. I did the MSD Blaster Coil, MSD Cap/Rotor,MSD 8.5mm superconducter wires and Rapidfire Plugs and the car ran great. I deffinetly recommend this setup to anyone.
Old Dec 21, 2001 | 05:41 AM
deadtrend1's Avatar
hmm, now you got me thinking about spending more of my money
Old Dec 21, 2001 | 08:37 AM
RS91's Avatar
I just installed my Cap and rotor. I tried driving a few blocks and it seems a bit smoother compare to when I just installed my MSD Blaster coil...
Old Dec 21, 2001 | 09:31 AM
TBI305Camaro's Avatar
any HP gains? where did you mount the coil? and how did you hook it up to your stock wires that go into the coil (sorry dont know the name) i think MSD makes a kit that is a direct replacement for the 5.0 TBI and it hooks up just like stock, comes with the cap, rotor, and it produces somewhere around 53,000 volts
Old Dec 21, 2001 | 10:34 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Hey this is great I was just about to post a question on the same topic.
I have the MSD wires and remote coil already. I was planning on installing the ignition box soon. Should I expect to see any noticable HP gains after installing one or just a smoother running car? Also I don't know what set up you guys have on yours but mine has the remote coil. Is it alright to run an MSD ignition with wires and coil in combination with the stock distributor? Eventually I would like to install an MSD distributor but have other mods I would like to do first.
Mark
Old Dec 21, 2001 | 01:25 PM
Like I said I have a MSD direct GM fit coil and cap&rotor i'll sell all for $40 shipped. All has 300 miles on it.
Old Dec 21, 2001 | 07:28 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
You get no Hp/tq gains from the MSD Box or any ignition part for that matter. You get better spark which gives u a smoother idle, quicker starts.
Old Dec 22, 2001 | 04:15 AM
RS91's Avatar
MSD makes Direct replacement and the part no is MSD 8226 for the Blaster coil...
Old Dec 22, 2001 | 07:32 AM
RS91's Avatar
I tried installing the MSD spark plug wires but I could not figure out which end goes to the distributor. One end is plain and the other has the MSD Logo on it. Which end goes to the distributor?
Thanks...
Old Dec 22, 2001 | 10:45 AM
MSD END GOES TO SPARK PLUGS
Old Dec 22, 2001 | 10:48 AM
Silverado5.7L's Avatar
mileage
Has anyone recieved economy gains with the installation of the Coil?
I was thinking about getting one for my truck.
Old Dec 22, 2001 | 01:17 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Is there a possibility of recieveing an error code from my comp after installing an ignition box? Where is an ideal spot to mount it?
Old Dec 23, 2001 | 12:23 AM
RS91's Avatar
Thanks for that info Cody... I just finished installing it. I'm very satisfied with the whole set up. The only thing that I did not like was the wire for spark-plug 6,8 and 5 they should have been straigt boots instead of 90*. And the wire for no 6 spark plug was a bit tight. They should add about 1" more .
Again thanks...
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
