Fuel leaking from throttle body
Old Dec 6, 2015 | 12:33 PM
David Fite's Avatar
Car: 1986 IROC-Z
I had to take my TB off yesterday to figure out a sticky throttle problem. Well the fuel inlet and outlet on the back were really hard to get back in with those hard lines. Hopefully I didn't cross thread them. Anyway both are leaking. Is there a trick to putting those back on? I've tightened them pretty hard already. The main bolts that go into the TB r in good shape. The nut sleeve things r a little rusty, but the leak seems to be where the main bolt meets the TB.
Edit: are there supposed to be little gaskets on those bolts that go into the TB?
Old Dec 6, 2015 | 12:46 PM
David Fite's Avatar
Car: 1986 IROC-Z
Re: Fuel leaking from throttle body
Herr is one of the bolts. No idea if it looks good or not?
Old Dec 6, 2015 | 03:05 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Supposed to have a plastic washer at the indented portion at the end of the screw point.
Old Dec 6, 2015 | 03:11 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
You should have plastic washers on those. I got mine in a Tb rebuild kit. Those lines won't seal without them. You may be able to get them seperate but not sure about that.Make sure that the old ones are not still in the Tb. Hope this helps
Old Dec 16, 2015 | 06:33 PM
morgsie's Avatar
should also replace the rubber o-rings on the fuel lines themselves. while you can sometimes reuse them most of the time they are NFG...
Old Dec 22, 2015 | 09:38 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
I seem to have a similar issue with getting one of those lines back in place right everytime I remove them on my car. I have a TBI pod spacer on mine so I raises mine up just a little. 2 things I always do with mine since I ruined one of the pieces on mine after the first time doing this. There should be a bolt or nut on the drivers side near the valve cover I think, you can loosen this and you should be able to manuever the line a little more. Second thing is I usually get someone to help me by holding the line in place while I try to tighten the fitting in place.
soarestransam
Jan 31, 2016 06:47 PM
Linson
Dec 22, 2015 02:26 PM
wolftamer389
Brakes
Dec 11, 2015 08:56 PM
FormulasOnly
Dec 8, 2015 09:11 PM
2012sergen11
Dec 4, 2015 10:15 PM
