Looking to rebuild my 9 bolt
Old Dec 1, 2015 | 09:14 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok everyone my 89 pbr rear end 9 bolt 3.27 ring gear has developed a slight hum so i want to rebuild the whole rear end new ring and pinion, axles, spider gears, axle seals bearings pinion gear seal etc etc i have the part number for the axles, and ring and pinion but i cant find the rest can someone help me out this diff has 155+ miles and the p/s axle seal is leaking anyway
Old Dec 2, 2015 | 07:25 AM
big gear head's Avatar
Re: Looking to rebuild my 9 bolt
Why do you want to replace the axles? Unless they are bent they should be fine.
Old Dec 2, 2015 | 07:44 AM
Twin_Turbo's Avatar
and why the ring and pinion, inspect. If good, reuse.
Just need bearings, axle collars, seals,shims. Ratech has most if not everything.
Old Dec 2, 2015 | 09:00 AM
The Yukon installation kit is a very good one for the 9 bolt. You will also want to inspect the cones and see if they have bottomed out, or if they are close. This would be a good time to have that repaired if needed.
Old Dec 2, 2015 | 05:38 PM
Engine: LR4 4.8
Ok what i meant to say was i want t install 3.70's since mine has the stock 3.27 in it what would i need to complete this install
Old Dec 2, 2015 | 05:51 PM
The Yukon installation kit, axle bearings and seals and a set of 3.70 gears. As far as I know all of the 3.70 gears make some noise. Randy's Ring & Pinion has all of the parts you need. I think Summit also sells the Yukon parts.
Old Dec 6, 2015 | 05:37 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Check out this website too.
http://9bolt.com/index.html
Old Jan 25, 2016 | 06:32 PM
JD Z28's Avatar
Car: 89 Iroc Camaro
Engine: 5.7 l98
Axle/Gears: 3.70
http://www.drivetrainspecialists.com...t-borg-warner/
This is the exact same thing I did to my Iroc. The pinion seal was leaking and I could not figure out why. come to find out, some one had installed a 10 bolt ring and pinion and did a crappy job shimming it up. I looked all over the internet trying to find the stock replacement. 9bolt.com was one option but had very delayed response which was very frustrating. 9bolt.com is a little cheaper but the stock replacement parts they have are used. i had the extra money at the time so i went for the 3.70 R&P and the install kit from Drivetrainspecialist. hope this helps
Old Jan 25, 2016 | 09:58 PM
yaj15's Avatar
Car: 1988 IROC-Z
How do you like your car with those 3.70 gears? I've always been told that 3.7x gears would keep a TPI motor out of the powerband. Those 3.70 gears are the only "new" gears that I've been able to find though.
Old Jan 25, 2016 | 10:10 PM
JD Z28's Avatar
Car: 89 Iroc Camaro
Engine: 5.7 l98
Axle/Gears: 3.70
Well, my car also has a mild cam and short tube headers. So it's definitely got some more pep, mostly on the low end but it still goes through the power band pretty well.
Old Jan 31, 2016 | 06:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
PM Sent:
Old Jan 31, 2016 | 06:47 PM
JD Z28's Avatar
Car: 89 Iroc Camaro
Engine: 5.7 l98
Axle/Gears: 3.70
I think the 3.27 gear uses a 3 series carrier which is also what the 3.70 gears uses.
Fechin
Mar 1, 2018 10:51 AM
Doobie52
Jan 8, 2016 12:33 PM
thorflynn15
25
Nov 16, 2015 08:04 PM
Degweiser
Nov 13, 2015 11:07 PM
Galaxie500XL
Nov 11, 2015 03:04 PM
