Emissions delete kit?
Old Dec 7, 2015 | 03:19 PM
Badmechanic125's Avatar
Car: 1983 Z29 T-Top Camaro project.
Engine: 305 V8 Cross Fire Injection
is there such thing so i could get rid of all the emissions crap on my camaro im switching to a carburetor but there is a ton of hoses and wiring that doesnt seem neccesary is there a way to get rid of all this stuff ? and still have it run normally?
Old Dec 7, 2015 | 07:08 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
Re: Emissions delete kit?
Why on earth are you getting rid of the TBI?
You can tune a TBI cheaper then buying a new carb.
you can buy a smog pump delete pulley and remove all that piping.
Old Dec 7, 2015 | 07:15 PM
Well the owner before me who gave it to me for free said the Cross fire injection broke 10 years ago and its been sitting in his yard so i am going to put a carb and intake and all that stuff for right now until i get out of highschool then ill probably restore it with cfi
Old Dec 7, 2015 | 07:22 PM
Westech's Avatar
Car: 1991 Camaro RS
Broke the cross fire? You can buy every single part for that cross fire on line.
You might want to take a look on what is going on with the car before you try to put a carb on a injected engine.
You will need to install a new distributor, intake, carb, fuel pump, fuel lines, wiring for the distributor, vacuum lines, if the car is automatic you will have to install a aftermarket control kit.
Old Dec 7, 2015 | 07:29 PM
ah i see do you know a good website to get some cross fire parts?
Old Dec 7, 2015 | 07:33 PM
Westech's Avatar
Car: 1991 Camaro RS
ebay....or do a little google searching.
like I said take a look and see whats wrong and go from there.
Old Dec 7, 2015 | 07:35 PM
Alright thanks for the advice
Old Dec 13, 2015 | 05:54 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
common for TBI/CFI injectors to be stuck if they sit unused for a while-easy to unstick them if they are stuck.Also sometimes the foam rubber coupler hose on the in-tank pump turns to mush and fuel pressure is lost.Bad ECM is possible but rare-just have to start checking things and the problem will be found.
85@IRocZ
Dec 15, 2015 05:22 PM
dragonmas
Dec 5, 2015 10:11 AM
hotrodjames
Nov 22, 2015 07:45 PM
camaroz1979
Nov 19, 2015 12:17 AM
qward22
Nov 17, 2015 04:20 PM
