Holley TBI??
Old Dec 21, 2001 | 10:53 AM
JuGrNuT350's Avatar
Holley TBI??
Whats the deal w/ thing being for 87-89 TBI units only?? Did they change the TB at all in 90? I want to try to get the most out of my TBI 350 in my 90 Sierra and the Holley TB was part of it.
-Timbo-
Old Dec 21, 2001 | 04:19 PM
deadtrend1's Avatar
1988 on had two injectors instead of one, but i dont think they changed anything. Of course my TB history is a little vague.
~Tim
Old Dec 22, 2001 | 05:36 PM
JuGrNuT350's Avatar
The Holley TB flows a lot better than the stock GM right? So would it would work on the 90-95 V8s as well?
-Timbo-
Old Dec 23, 2001 | 02:41 AM
JPrevost's Avatar
Car: 91 Red Sled
All TBI was 2 injectors unless you're talking about something other than a v8, if that's the case go check out the v6 board. TBI was found on crossfire setups way back when and that setup used 2 single barrel setups but with massive injectors (67#).
My dad's 87 suburban used the same 1 and 11/16" bore with 2 injectors as my 91 and his new truck, a 95 burban.
They all swap on and they all work. It's the larger 2" version that you need to make sure will fit your intake manifold (most likely not). You would need either a carb intake with an adaptor plate or a holley specific TBI 2" bore intake manifold.
As for the free slowing, holley isn't any better than a worked over GM unit. It's really easy to make the GM unit flow just as well. All you need to do is mill off the ridge runners on the top of the bore and maybe install a thicker injector pod spacer.
Old Dec 23, 2001 | 04:20 AM
DM91RS's Avatar
Car: 91 RS
I agree with JP and I might add to make your fuel pressure regulator adjustable.
For those that haven't been there the tech section has some good TBI projects. IE: the unltimate TBI. Parts one and two and an article on the AFPR.
Good luck!
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
Glowsock
Sep 11, 2015 11:09 PM
