Tools required to change 305 TBI injectors?
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I'll be changing the injectors on my '91 Camaro RS 305. I just wanna know if there's any special/unique tools I need to do the job? I've got sockets,wrenches,pliers,screwdrivers,etc.
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Tools required to change 305 TBI injectors?
Go buy yourself a nice set of torx bit sockets and standard flare nut wrenches from sears. The torx bits are required to remove the top plate on the throttle body. The rest of the car has torx bolts all over the interior so the set is a good investment. The wrenches you will need to pull the fuel lines off to relieve any residual pressure at the tb. Good luck!
