possible bad injector?
iv gor a 1994 chevy k1500 350 tbi with a small melling cam it felt like it had a BAD missfire so i put new plugs and wires and i replaced distributer cap and rotor button a few months ago along with tps iacv. still dident help so i did a compression test all cylinders were right at 150psi but number 8 dumped gas out and it was at 210 im assuming because all of the gas in the cylinder my first thought was a bent pushrod or cracked rocker arm on the exhaust side but i pulled the out and everything looked good and i was wondering if i could have some trash in one of the injectors and it be causing that to happen. any help would be appreicated its got me stumped
Re: possible bad injector?
Do the rocker arms on that cylinder MOVE appropriately? First Guess: Wiped cam lobe.
Your post would be easier to read and to understand if you'd have spent time to punctuate, capitalize, and provide paragraphs, appropriate spelling, and spacing. You would have learned all about that before you left fifth grade.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Start by replacing distributor first. The 94 dizzy uses external coil and are well known to accumulate moisture. A misfire in distributor due to reluctor ring corrosion can effect both spark plugs misfiring and misfiring of the injectors. TBI injectors hardly ever go bad. Get your ignition system healthy before getting into injectors.
//RF
//RF
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
//RF
//RF
i just put my new distributer in and map sensor, and im pretty sure the timing off it shot a flame out of the throttlebodie bit ill fix it tomorrow after work. hopefully it fixes it this time
