L98 Cammed Vortec
Old May 6, 2016 | 01:25 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
L98 Cammed Vortec
How well would a stock Vortec 350 with an L98 cam run on a stock 350 TBI tune running 68lb injectors? Ive thought on this build and it should make 250 fwhp and be easy on gas and a simple build without getting into a lot of tuning I suppose? The L98 cam has a lil more duration than the L31 cam and less lift so I know its good for stock vortec heads and maybe mild enough not to throw the stock tune out of wack. Im at the point of weighing out whether I want to stay TBI or go carb on my next build.
Old May 11, 2016 | 12:51 AM
89-S-dime's Avatar
Engine: 350 TBI build
Axle/Gears: 3.73 G80
Re: L98 Cammed Vortec
I dont know about the stock TBI tune with 68lb injectors, what fuel pump are you using?
Old May 11, 2016 | 07:22 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Well im sure if I do the swap I will use the Walbro pump I hear good things about. Im sure my stock TBI pump probably wouldn't be enough. I would plan to install a regulator probably having to get the pressure bumped up some
Old May 22, 2016 | 02:44 PM
92CamaroDE's Avatar
Car: 1992 Camaro RS
Engine: 5.7 Vortec with TBI
A TPI fuel pump will also work well.
I think I would go with an LT1 cam as opposed to the L98 cam. The Vortec 350 flows well and the larger cam will wake it up. It is still small enough to work with the Vortec lift limits and will not need additional machining of your valve guides. I swapped from a 305 TBI to the Vortec 350 with TBI and would suggest getting EBL Flash. It's not cheap, but is worth every penny. Wasted money on mail order tunes but results were not even close to being able to tune it myself on the fly. Also, your stock TBI unit most likely will not flow enough CFM for the Vortec 350 with either cam. You will most likely need a 48 MM or 50 MM bored out one. I think your stock tune will be off both in fuel curve and timing table. It may run, but will leave a lot on the table.
Old May 22, 2016 | 11:51 PM
89-S-dime's Avatar
would also recommend using a LT1 cam
Old May 23, 2016 | 09:43 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Those injectors will keep the tune tricky I would go down to stock to minimize fueling tunes from injectors and just work on cam tune. I wouldn't think it would be much tuning for an lt1 cam but prom board should be able to chip in
Old May 27, 2016 | 02:37 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
68# is not enough injector, it needs the 80# 454s.
Old May 27, 2016 | 09:02 PM
maks10's Avatar
Car: 1990 Trans Am
^^^sorry I misspoke but after searching it seems 68# maybe ok not sure higher but I'd probably chime in prom board.
Old May 29, 2016 | 09:24 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
68s will not be enough fuel for even a stock cammed L31. With the tiny 395' marine cam my L31 with the stock truck intake, tri-y headers into stock cats and exhaust put down 230 rwhp and 303 rwtq through a 4L80E and GM 9.5 14-bolt. The stock truck MFI setup is 23.1 lb/hr each at 62 psi and I am running 70 psi for about 24 lb/hr. Running at 86% injector duty cycle to hold 12.6:1 at 5,200 rpm.
Old Jun 2, 2016 | 07:14 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I imagine if I do build another engine then I will NOT be keeping my TBI. It just limits power so much its so much easier to go with a carb.
Old Jun 2, 2016 | 08:55 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Doesn't limit it much at all if you have the EBL or newer P4 PCM and a 454 TBI on a carb intake.
Old Jun 6, 2016 | 08:30 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Honestly I wouldn't go anywhere near an LT1 cam with Vortec heads. The smallest cam I would run would be a ZZ4 cam with 1.6 rockers on the intake and 1.5 on the exhaust using Blue LS7 springs to accommodate the lift. With a 454 throttle body I could damn near guarantee 300+ hp.
Old Jun 6, 2016 | 09:58 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Looking at a Herbert Roller cam. 215-225 440 465 lift. 2000-5700 RPM range. Upgraded Vortecs with Beehive Spring set. And instead of keeping the TBI and the hassle of tuning just going with a good Holley 650. But im still in planning stage at this point. First im getting paint between now and Octobers Cruisin the Coast.
Old Jun 16, 2016 | 05:01 PM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
Might check out the lt4 hot cam they do pretty good with the l31 vortec. Use the right springs and retainers without machine work on the heads.
HerpDerp1919
Jun 18, 2021 01:03 AM
Michael Harding
Carburetors
Apr 4, 2016 05:23 PM
Dfdub92
Mar 28, 2016 09:47 PM
philmcgroin
Exterior Parts for Sale
Mar 28, 2016 02:13 PM
JL2000
Mar 16, 2016 05:26 PM
