breather filter question
Old Dec 25, 2001 | 12:14 AM
TBI305Camaro's Avatar
ok...i took the stock tube for the breather and cut it down towards the straight part at the bottom and used a ballpean(sp?) hammer to widen the part just alittle to be able to fit my "clamp" on k&n breather that i relized would never clamp on to that huge tube...so i squeezed it in there and now seems like im getting oil somewhere cause its smoking alittle around the valve cover...probably coming from that....i havent got a chance to look at it in daylight tho....is this going to hurt anything? my oil pressure seems fine...is it to restrictive or anything?
Old Dec 25, 2001 | 10:21 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
shouldn't be a problem, you might wanna put some permatex around the inside of the connector to sel it up. It''s probably leaking out somewhere, and geting onto the head.
Brinkkl2000
Aug 4, 2018 08:29 AM
db057
Aug 22, 2015 08:17 PM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
