TBI 305 build input appreciated
Car: 1991 Firebird
Engine: 305 tbi Stock
Axle/Gears: 2.73 posi
My latest bird has the mini mouse l03 305 i got this car for 400$ its only has 48xxx miles on the clock. i want to keep it numbers matching but wake it up some maybe build something better later on. I've read and poked around i know 305's aren't loved like a 350 but i am working with what i got anyone got any changes to what i have selected so far listed below?
Summit Racing® Stage 1 Intake Manifolds SUM-226016
Chevrolet Performance LT4 Hot Cam Hydraulic Roller Cam Kits 12480002
Trick Flow® Super 23® 175 Cylinder Heads for Small Block Chevrolet TFS-30310006
(obx knock off headers) http://www.ebay.com/itm/STAINLESS-STEEL-LONG-TUBE-HEADER-EXHAUST-MANIFOLD-Y-PIPE-FOR-82-92-CAMARO-SBC-AT/381245539326?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35389%26meid%3D0b1d9515bc39420492f1c6cdaeb51e15%26pid%3D100005%26rk%3D1%26rkt%3D6%26mehot%3Dpp%26sd%3D391131469413
Axle/Gears: 10 Bolt 2.73 Open
Re: TBI 305 build input appreciated
Looks like some nice pieces. And will fit other SBCs if you ever go for more cubes.
Why the FM rebuild kit? Are you re-sealing the engine? Or new bearings, etc.? Looks like a full rebuild, new pistons, etc. Is that all needed?
Maybe consider another kit without pistons, and buy your pistons seperately, and get some that bump your C/R?
Car: 1991 Firebird
Well, I'm usually in your camp...building the 305 because I have it. But if your going for a full rebuild, with it's accompanying machine shop bills, the only difference left in cost between the 305 and 350 is a donor 350. For those comparatively fewer dollars more, I'd make the jump, get the cubes and better breathing (unshrouded valves).
Car: 1991 Firebird
actually im not gonna go with a .30 over bore or a full rebuild with under 50xxx ill just replace the fms and rms call it good enough and ill go with the Trick Flow® Super 23® 175 Cylinder Heads for Small Block Chevrolet TFS-30310006 over my original choice so i don't have to change anything for the lift of the hot cam.
Car: 92 Camaro
Axle/Gears: stock
For the TBI spacer plate, I just got one off ebay from a company called Inject it, PN-Inject-001. It's a 1/2" of machined billet aluminum, and use a typical 4 barrel spread bore gasket for the underside of it-it has recommendations for which one to use but I can't remember. It was I think about $70 shipped roughly. I looked at trans-dapt and there's were no where as nice as this one is.
Scorched1984
Mar 13, 2016 10:10 AM
STL1994
Aftermarket Product Review
Nov 17, 2000 01:10 AM
