Sputtering and popping on acceleration
Old Apr 1, 2017 | 02:42 PM
Ben Thomson's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 TBI
When I was accelerating in my RS today (305 TBI) there was a hesitation and sputtering sound followed by a "pop" (possibly backfire?)
It seemed to be running really rich and stumbling at idle, with RPMs hovering around 500.
I took off the intake and I looked at the injectors. Here's a video:
Is this too much gas for idle? It seems like a lot.
Do I need an injector/IAC rebuild?
Old Apr 1, 2017 | 02:43 PM
Engine: 305 TBI
Re: Sputtering and popping on acceleration
When I floor it, black smoke comes out of the exhaust but only for a second
Old Apr 1, 2017 | 04:52 PM
Schurkey's Avatar
Connect a scan tool.
What are the values for O2 sensor voltage, O2 crosscounts, coolant temp sensor, short- and long-term fuel trim, and MAP sensor?
A cylinder-balance test would be wonderful, too.
Old Apr 2, 2017 | 12:00 PM
Engine: 305 TBI
Okay I bought a code reader so I'll let you know when I get it. But just by looking at it, does there seem to be too much fuel being injected? It's dripping down the sides of the throttle body bore
Old Apr 2, 2017 | 02:10 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Usually popping and such is caused by running too lean, timing is off, or your valves aren't seating.
Old Apr 2, 2017 | 02:46 PM
Schurkey's Avatar
A "code reader" does not access the data stream. They're almost worthless.
Return it and get a scan tool.
Old Apr 2, 2017 | 07:26 PM
Engine: 305 TBI
Sorry, I was being colloquial. I got the ALDL -> Serial Port cable. The one that you can use with TunerPro and WinALDL
