VAFPR Question in concern to the EBL, Calling RBob...
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Hey guys I have a question. When setting my VAFPR am I supposed to set the fuel pressure with the hose connected to the vacuum line or disconnected?
I'm guessing connected right? As vacuum decreases the FP should increase correct?
Re: VAFPR Question in concern to the EBL, Calling RBob...
So I'm going to guess that all of my popping out the exhaust from a rich mixture is going to magically go away once I do this...
Car: check
Engine: check
Transmission: check
