High idle problem on TBI?!?
Old Jan 2, 2002 | 12:40 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Hi!
Today I tried to help a friend who has an '89 Chevy van /w a 350 TBI in it.
His problem is that the idle goes up as far as 2000-2500 rpm suddenly, and then it goes back to normal after a while.
I helped him remove and clean the IAC, which I first suspected to be the problem, also checked the throttle linkage and it moves smooth and goes back fully when I take the foot off the accelerator....
All vacum lines seems to be in order, what else can cause a problem like this?
I was thinkping maybe MAP sensor?
Old Jan 2, 2002 | 02:57 PM
TBI305Camaro's Avatar
could be the map...sounds like a fuel spike maybe or a vaccum leak
Old Jan 2, 2002 | 09:23 PM
JeffC1500TBI's Avatar
I'd check the fp.. to eleminate the iac you can unplug it and see what happens
Old Jan 3, 2002 | 12:56 AM
ZaphodB's Avatar
Already tried with a replacement IAC, he's going to get a new MAP sensor for it today and see what that gives. Didn't have my laptop with me yesterday, but if that doesn't help I'll hookup the computer and see if something looks funny...
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
