could a new breather cause this...
Old Jan 2, 2002 | 02:52 PM
TBI305Camaro's Avatar
ok i started leaking oil after installing a k&n breather filter...its a "clamp" on breather but i figured out there was so way it would clamp on to the stock pipe so i cut the pipe down and widened it alittle to make the "clamp" on breather into a "push in" breather...could this is causing my oil leak? i thought i had it fixed but its still there just not as bad....the hole for the breather is pretty small so could it be to restrictive? now i leave a golf ball sized puddle of oil after the car has been turned off...it was softball ize before i replaced the drivers side valve cover gasket which i though fixed it...should i go ahead and do the other side?
Pac J
May 17, 2020 10:44 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
luvofjah
Sep 26, 2015 08:28 PM
sleprock
Sep 24, 2015 04:33 PM
