High idle on 90 TBI HELP Please !!
Old Jan 25, 2018 | 06:27 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Hello. I recently bought a 90 Formula 305 5 speed. Stock tbi stock heads and stock cam. Car had a chip burned to eliminate vats. Car just had new head gaskets, new reman TBI unit and new injectors(stock) put on and headers installed all at the same time. Smog was deleted. Car has a new fuel pump. Car idles very high, around 1200 rpm even when warm after driving . Car ran fine when it was stock, the old tbi had a bad injector and leaking throttle shaft so the tbi unit and inj was replaced. Car has new plugs,cap ,rotor, wires tps IAC. Fuel filter was done last year, I will replace that to see if that is causing the high idle. Maybe a vaccum leak or egr. Has open elelent air cleaner. I want to buy a stock air cleaner back on to help eliminate that Car has 02 sensors still.
Old Jan 25, 2018 | 07:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: High idle on 90 TBI HELP Please !!
If the thermostat was replaced with a lower temperature unit put a 195 back in. If the IAC steps (scan tool required) is at zero then look for a vacuum leak.
Note that the fan isn't ECM controlled, so can't burn a chip to lower the fan on/off temperatures.
RBob.
Old Jan 25, 2018 | 08:26 AM
I will check the thermostat and Iac. Will the headers make a high idle with the stock 02 sensor? Will a heated 02 help at all. The previous owner did a vacuum check with spray. I will try to have a smoke test done to find the vac leak. Thanks for your help.
Old Jan 25, 2018 | 10:44 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Have you tried just resetting the IAC?
https://www.thirdgen.org/tpimod2/
Old Jan 25, 2018 | 10:54 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The o2 will help with idle air fuel mixture in closed loop.
A common place for a vacuum leak on tbi is the base plate on the tbi unit .
You might want to run a afs-74 o2 but it’s not the cure for your issue of high idle.
Zach/90\irocZ
Mar 13, 2012 08:15 AM
Sonymaster20
Feb 3, 2011 10:34 PM
racerquinny
Dec 3, 2008 12:05 AM
80smetalfan
Mar 21, 2006 05:01 PM
BuckeyeROC
Aug 12, 2001 12:05 PM
