Another TBI idle Problem, Coming to a stop and high idle...
Old Jan 18, 2011 | 11:38 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Hey guys I have a 92 Camaro Rs I just totally restored, engine is a fresh rebuild with everything going in new. I just have a question, I got everything running, it is timed at about 6 degrees and have everything plugged in. (all vacuum hoses no leaks,). The problem is when i'm coming to a stop, the engine remains at a high idle, about 1250 rpm, to almost 1500. I dont think it is the normal throttle body sticking, because it doesnt happen when the car is parked, but I am wondering what might it be.
Any information or tricks would help.
Old Jan 18, 2011 | 11:43 PM
notoriouscamaro's Avatar
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
Re: Another TBI idle Problem, Coming to a stop and high idle...
I have the same problem with my car. I feel like it onl does it when it's warming up. I have not rebuilt my engine or anything and have 130k.
Old Jan 19, 2011 | 01:10 AM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
Mine is when it is warming up and when I come down to idling. I also have some pretty high oil pressure according to the gauge, around 45 psi?
anthing would be great guys
Old Jan 19, 2011 | 06:38 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Mine is very high too!
Old Jan 20, 2011 | 06:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Any codes showing?
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
https://www.thirdgen.org/forums/post...740-post4.html
Old Jan 20, 2011 | 10:04 AM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Would any lights come up on the dash?
Old Jan 20, 2011 | 11:27 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you make sure the EST was unplugged when you set your timing. 6° base is a little too much for these cars. It isn't required with the swirl ports and can cost you driveability. I would check the timing, set it to base 0 and go from there. Might be a good time to check TPS voltage as well.
Old Jan 20, 2011 | 12:20 PM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
I am not getting any codes or anything, just a weird bit on the idling coming down and a fluxuation on start up, Nothing horribly bad but it is annoying on a new engine.. I am going to check these things out here in a bit, I am at work today and will check it when I get off.
Old Feb 3, 2011 | 10:34 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Have you found a solution to this issue? I'm having the same problem still. Maybe it's my IAC??
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
