Build Questions
Build Questions
Hi All,
Just ordered the APU-1 kit from moates and officially set in motion my build to get my suburban back to being reliable.
Previously I build an L05 with stock swirl port heads and did no tuning to it while putting in a summit k1102 (.421/.443 112 LSA IIRC) in it. It ran OK but never like I wanted it to.
I am planning this time on buying a Chevy performance L31 long block as a jumping off point and possibly upgrading the cam to build more low end torque. It just seems this is cheaper than having a block remachined/etc.
With that I plan on bumping the stock injectors (should be either 61# or 65# I believe) up in pressure to compensate for the better flow using an AFPR and upgrading to the stock AC Delco pump for the 96-up vortec trucks (higher pressure than the TBI pump). Also will be running a carb'd intake (no smog where I live)
Question mainly is a couple things. First of all, has anyone had a build like this? Secondly, what is the cam limit on stock L31 heads, I have read nothing over .450" which seems awfully small but it seems you can change springs/retainers and get around this without machining?
Any help is appreciated. Thanks!
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Build Questions
0.480-0.490 is the upper limit on all the L31 heads I have had in my possession. You can use a GM LS6 spring and a Comp 787 retainer on them and get clearance for 0.550" lift.
If you are looking for low-end torque, it is hard to beat the GM 395' Marine cam that comes in the Ramjet and HT383 engines as well as thousands of ~300 hp boat engines.
The GM Ramjet crate engine has 0.461/.0481" lift with the 395' cam and its factory 1.6:1 roller rockers on factory Vortec heads.
Re: Build Questions
I'm also struggling to navigate the forum and find a base tune to start with, which I have concerns about. I don't want to fire on the stock L05 tune and have the engine running terribly lean.
Again I am a novice, and I am a bit nervous to do this, although I am confident I am capable of it.
edwardk12687
Jul 21, 2014 02:22 AM
