Sources for 48mm blades?
Old Jan 5, 2002 | 02:58 AM
Tas's Avatar
Tas
I didn't find any sources in the search. Anyone know, or know they type of metal and thickness of TB blades so new ones could be made?
Old Jan 5, 2002 | 03:01 AM
Jza's Avatar
Jza
16 gauge aluminum?
Ask snuf, he probably knows all the sources from back when he was looking all over for TB blades...
Old Jan 5, 2002 | 03:24 AM
Tas's Avatar
Tas
I don't think they would be aluminum. I was thinking stainless steel or zinc plated steel.
Old Jan 6, 2002 | 12:53 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
They're steel, or stainless steel (some kinda ferrous metal). You can get 48mm blades from a stock TPI throttle body. Thats what I did.
It would be real hard to make them since the have a bevel to them.
Old Jan 6, 2002 | 01:57 AM
Tas's Avatar
Tas
Can you explain the bevel part?
Old Jan 6, 2002 | 08:46 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
The throttle plates aren't perfectly square. Meaning, if you laid them flat on a table, they would have and angle to the edge. I think they do that so the edge does not cause the plate to bind in the bore when the plates are closed.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Dec 2, 2015 03:53 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
